It is currently Mon Jul 28, 2025 2:36 pm
PostPosted: Thu Aug 21, 2008 11:55 am
City: Jacksonville
Funny how things happen. I have two clients, different clients, that both have Holly trees in their landscapes they would like removed. One of the trees has ATLEAST 8 feet of clear trunk and is about 14 inches in diameter. The other is smaller, about 4 ft of clear trunk and about 8 inches in diameter.
Anyone know what the potential value per yielded and dried bd/ft is? Are there any known problems with drying? After the storm passes I am scheduling the removal of these trees.
Thanks!
Chris
PostPosted: Thu Aug 21, 2008 12:11 pm
Holly is reputed to be very difficult to dry, warping and twisting a lot. Good luck!
PostPosted: Thu Aug 21, 2008 1:32 pm
Lute/early instrument builders like it (for imitation ivory)
PostPosted: Thu Aug 21, 2008 1:55 pm
City: Jacksonville
Todd - how did it bend as binding stock? I really don't think I could get anything out of this beyond binding material, headstock veneers, rosette material,...stuff like that.
PostPosted: Thu Aug 21, 2008 2:12 pm
It bends like rubber, you barely need heat to bend it.
PostPosted: Thu Aug 21, 2008 2:14 pm
Thanks!
Chris
It turns grey pretty easy, I somewhere read a way to prevent this, but can't recall what it was.
It makes great bindings. White without resorting to plastic.
PostPosted: Thu Aug 21, 2008 3:45 pm
City: Jacksonville
does anyone know what a set of holly bindings is worth? I really don't want to go thru the steps required to make this stuff desirable if it's not a sought after lumber as lumber relates to guitar making.
...and thanks a bunch for the input so far.
PostPosted: Thu Aug 21, 2008 5:52 pm
I've harvested a few Holly trees over the last 3 years, so far no problems with warping, twisting, etc. It is all still stickered though and will be at leat another year until I use any of it. Supposedly most stained binding (i.e herringbone) is holly. Way too soft for anything luthier related other than binding.
PostPosted: Thu Aug 21, 2008 6:00 pm
hi sniggly
this is what we’d do wth it round these parts
yup it's a bagpipe chanter. (Uilleann) there's plenty o' makers.
in the US who might want it if seasoned right and the quality good.
Start here -
http://chiffboard.mati.ca/viewforum.php?forum=6&210
yours Geordie
some tunes on acoustic and guitar synth.
http://www.youtube.com/user/TheGeordieAdams
http://www.myspace.com/geordieadams
PostPosted: Thu Aug 21, 2008 7:31 pm
I can't imagine it is worth more than $5 a stick on the super high side.
PostPosted: Thu Aug 21, 2008 9:11 pm
City: Jacksonville
:shock: :shock: :shock: "...$6 dollars a bd/ft for holly?"
The local woodcraft here has a few boards....they are $29 dollars a bd/ft. Not kidding.
PostPosted: Fri Aug 22, 2008 7:08 pm
I get alot of classical makers and lute builders wanting holly and i get my stock from scotland.
i wont tell the price i get for but $6 a b/f sounds about right.
the problems i have with it is yes it does warp twist and split when drying (i buy air dried stock) and it suffers greatly from big ol knots and even the clear areas have pin knots.
out of the lumber i buy only 1 third gets used for guitars (the rest is scrap) then it gets cut into bindings and head veneers and every binding strip is then checked for pin knots(a bloody booring job i might add).
i hate to discard the ones with pin knots so these are sold as seconds to lute,banjo,uke etc makers who dont need as long strips.
The point i am making is that is usualy full of knots.
it also can go grey when drying which is unpleasent.
apart from that it is very stable once dry (in fact gibson used to use for mandolin necks) and has a supurbe fine texture and bends like a dream.
If it wasent so wastfull the bindings and head veneers would be dirt cheap but it is a nice wood if you can get past the its negatives.
Its not a comercial timber here becouse of the fact it has to many knots but if you need white binding nothing is quite as stricking.
I think your native american holly is not as wastfull as the stock we get here so you may get a better yeild i thats the case then its a lovely wood (denser that you might think too)
Joel.
PostPosted: Fri Aug 22, 2008 7:35 pm
City: Jacksonville
Thanks to all of you....as Yoda would say...
"A big help you were!!"
laughing6-hehe
Users browsing this forum: meddlingfool, pullshocks and 15 guests
